Introdução
If your controller does not turn on, you've come to the right place. This guide will walk you through how to replace your controller's batteries. You do not need any special tools.
Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
Slide the cover off and separate it from the controller.
Um comentário
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
