Ir para o conteúdo principal
Dell Studio XPS 1647 Hard Drive Replacement
O que você precisa
  1. Dell Studio XPS 1647 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch to the side. {2}
    • Slide the battery out of the battery bay. {1}
  2. Dell Studio XPS 1647 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32
    • Loosen the ten captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Dell Studio XPS 1647 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the three screws securing the hard drive assembly to the computer base.
    • Pull the blue pull-tab to disconnect the hard drive assembly from the system board connector.
    • Lift the hard drive assembly out of the computer base.
  4. Dell Studio XPS 1647 Hard Drive Replacement: passo 4, imagem 1 %32
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging .
    • Remove the four screws that secure the hard drive bracket to the hard drive and remove the bracket.
  5. Dell Studio XPS 1647 Hard Drive Replacement: passo 5, imagem 1 %32
    • Pull the interposer to disconnect it from the hard drive.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 288
