O que você precisa
Slide the battery release latch until it clicks into place.
Slide the battery out of the battery bay.
Remove the six screws that secure the base cover to the computer base.
Lift the base cover off the computer at an angle as shown in the following illustration.
Remove the four screws that secure the hard drive assembly to the computer base.
Using the pull-tab, slide the hard drive towards the left to disconnect the hard drive assembly from the connector on the system board.
Lift the hard drive assembly out of the computer base.
Lift the hard drive off the hard drive cage.
Pull the interposer to disconnect it from the hard drive.
Uma outra pessoa concluiu este guia.
Um comentário
Can you provide instrcs. For connecting and installing the new hard drive? Where is the best place to purchase new drive and name/description for new drive. I have never tried this but my hard drive fails at least 2 tests
My battery is old and I have always had to keep it plugged into power should I replace it also for better performance? And best place for good price. Thanks
Della
Dellacmurphy@gmail.com
