Ir para o conteúdo principal
Dell Studio 1745 Hard Drive Replacement
O que você precisa
  1. Dell Studio 1745 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1745 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32
    • Remove the six screws that secure the base cover to the computer base.
    • Lift the base cover off the computer at an angle as shown in the following illustration.
  3. Dell Studio 1745 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Studio 1745 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Dell Studio 1745 Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Remove the four screws that secure the hard drive assembly to the computer base.
    • Using the pull-tab, slide the hard drive towards the left to disconnect the hard drive assembly from the connector on the system board.
    • Lift the hard drive assembly out of the computer base.
    • Remove the four screws that secure the hard drive cage to the hard drive.
    • Pull the interposer to disconnect it from the hard drive.
    • Lift the hard drive off the hard drive cage.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 296
