Ir para o conteúdo principal
Dell Studio 1737 Keyboard Replacement
O que você precisa
  1. Dell Studio 1737 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Studio 1737 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: passo 4, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 4, imagem 2 %32 Dell Studio 1737 Keyboard Replacement: passo 4, imagem 3 %32
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: passo 5, imagem 1 %32
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: passo 6, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: passo 7, imagem 1 %32 Dell Studio 1737 Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the ribbon cable as shown
Conclusão
Joseph Jacavone
Membro desde: 03/10/17
785 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 684
