Ir para o conteúdo principal
Dell Studio 1737 Hard Drive Replacement
O que você precisa
    1. Dell Studio 1737 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Studio 1737 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
      • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
      Pergunte ao FixBot
      Comentar
    1. Dell Studio 1737 Hard Drive Replacement, Back Panel: passo 2, imagem 1 %32 Dell Studio 1737 Hard Drive Replacement, Back Panel: passo 2, imagem 2 %32 Dell Studio 1737 Hard Drive Replacement, Back Panel: passo 2, imagem 3 %32
      • Unscrew the 8 Phillips head screws marked in the photo.
      • Even when the screws are fully detached, they will not come out of the panel.
      • Use a plastic opening tool to pry the panel away from the laptop body.
      • Lift the panel up and away.
      Pergunte ao FixBot
      Comentar
    1. Dell Studio 1737 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Studio 1737 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
      • Detach Hard drive from SATA connector.
      • Pull hard drive up and out pulling connector out of the way.
      • NOTE: your hard drive may be attached by screws or a bracket. This device had the hard drive just placed under the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 2,064
