Introdução
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
O que você precisa
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
