Introdução
If your screen becomes unresponsive you may need to replace it. A Philips 1 screwdriver and a plastic opening tool are required for this guide.
O que você precisa
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Insert a plastic opening tool between the bezel and the display cover.
Wiggle it to the release the latches.
Separate the bezel from the cover.
3 outras pessoas executaram este guia.
