O que você precisa
Place the laptop lid down so the underside is visible.
Pull battery release switch and gently pull the battery directly away from the switch.
Unscrew all of the 6.0 mm screws with a Phillips #1 screwdriver holding the hard drive cage on the computer.
3 outras pessoas executaram este guia.
Um comentário
Straightforward process with step by step guide. Thank you Zach.
