Ir para o conteúdo principal
Dell Studio 1537 Hard Drive Replacement
O que você precisa
  1. Dell Studio 1537 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Studio 1537 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Ensure the laptop is turned off and unplugged before attempting to remove any piece.
    • Place the laptop lid down so the underside is visible.
    • Pull battery release switch and gently pull the battery directly away from the switch.
  2. Dell Studio 1537 Hard Drive Replacement, Back Cover: passo 2, imagem 1 %32
    • Identify the back cover of the laptop.
  3. Dell Studio 1537 Hard Drive Replacement: passo 3, imagem 1 %32
    • Unscrew and remove all of the 6.0mm screws with a Phillips #1 screwdriver.
  4. Dell Studio 1537 Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the back cover off of the laptop.
  5. Dell Studio 1537 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Dell Studio 1537 Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Unscrew all of the 6.0 mm screws with a Phillips #1 screwdriver holding the hard drive cage on the computer.
  6. Dell Studio 1537 Hard Drive Replacement: passo 6, imagem 1 %32 Dell Studio 1537 Hard Drive Replacement: passo 6, imagem 2 %32
    • Lift the hard drive cage out of the laptop.
  7. Dell Studio 1537 Hard Drive Replacement: passo 7, imagem 1 %32 Dell Studio 1537 Hard Drive Replacement: passo 7, imagem 2 %32 Dell Studio 1537 Hard Drive Replacement: passo 7, imagem 3 %32
    • Pull tab to unplug the drive from the computer
    • Pull the hard drive out of the hard drive tray.
Conclusão
3 outras pessoas executaram este guia.
Zach Dylag
Membro desde: 03/24/15
575 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 6-2, Shaver Spring 2015 Membro de Baylor, Team 6-2, Shaver Spring 2015
BU-SHAVER-S15S6G2
Membros da 3
Autoria de 4 guias
Um comentário
Straightforward process with step by step guide. Thank you Zach.
Katharine Church - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 2,508
