Ir para o conteúdo principal
Dell Studio 1535 Hard Drive Replacement
O que você precisa
  1. Dell Studio 1535 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch until it clicks into place.
    • Turn the computer top side up, open the display, and press the power button to ground the system board.
  2. Dell Studio 1535 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32
  3. Dell Studio 1535 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the four screws securing the hard drive assembly to the computer.
    • Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
    • Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
  4. Dell Studio 1535 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
  5. Dell Studio 1535 Hard Drive Replacement: passo 5, imagem 1 %32
    • Disconnect the hard drive cable from the connector on the hard drive..
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
45.058 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 549
