Ir para o conteúdo principal
Dell Studio 1440 KeyBoard Replacement
O que você precisa
  1. Dell Studio 1440 KeyBoard Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1440 KeyBoard Replacement, KeyBoard: passo 2, imagem 1 %32
    • Turn the computer over and open the display.
    • Ease the keyboard surround up using your fingers or a plastic scribe.
  3. Dell Studio 1440 KeyBoard Replacement: passo 3, imagem 1 %32
    • Lift the keyboard surround off the computer.
    • Remove the two screws at the top of the keyboard.
    • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
    • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
  4. Dell Studio 1440 KeyBoard Replacement: passo 4, imagem 1 %32
    • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
    • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
    • Lift the keyboard off the computer.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 76
