Ir para o conteúdo principal
Dell Studio 1435 Hard Drive Replacement
O que você precisa
  1. Dell Studio 1435 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch to the side.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1435 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Dell Studio 1435 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the two screws on the hard drive assembly.
  4. Dell Studio 1435 Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the interposer to detach it from the hard drive.
    • Remove the four screws (two on either side) to detach the hard drive cage from the hard drive.
    • Lift the hard drive cage off the hard drive.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 351
