Ir para o conteúdo principal
Dell Precision T5600 RAM Replacement
  1. Dell Precision T5600 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
    • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Dell Precision T5600 RAM Replacement: passo 2, imagem 1 %32
    • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
    • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
  3. Dell Precision T5600 RAM Replacement: passo 3, imagem 1 %32 Dell Precision T5600 RAM Replacement: passo 3, imagem 2 %32
    • Line up the RAM with the groove on the connector line.
    • Do not touch the gold connectors.
  4. Dell Precision T5600 RAM Replacement: passo 4, imagem 1 %32 Dell Precision T5600 RAM Replacement: passo 4, imagem 2 %32
    • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
    • Ensure that both ends of the RAM are secured by their tabs.
  5. Dell Precision T5600 RAM Replacement: passo 5, imagem 1 %32
    • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
    • Once powered on, to verify the installation:
    • Right-click on 'This PC'
    • Left-click on 'Properties'
Conclusão
Fahad Khan
Membro desde: 07/05/21
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 752
