Introdução
This guide provides the necessary steps to successfully replace the video card in the Dell Precision T3400 desktop computer.
Lay the computer on its side so the panel faces up.
Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
Squeeze the two release tabs together and pivot the secure hatch to the right to open.
Hold the card by its top corner and metal bracket and pull it out of its slot.
Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
Close the card door and move the blue plastic secure lever back into place.\
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
8 outras pessoas executaram este guia.
Um comentário
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
