Ir para o conteúdo principal
Dell Precision M6800 Keyboard Replacement
O que você precisa
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: passo 1, imagem 1 %32
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: passo 2, imagem 1 %32 Dell Precision M6800 Keyboard Replacement: passo 2, imagem 2 %32
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: passo 3, imagem 1 %32
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: passo 4, imagem 1 %32
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: passo 5, imagem 1 %32 Dell Precision M6800 Keyboard Replacement: passo 5, imagem 2 %32
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: passo 6, imagem 1 %32 Dell Precision M6800 Keyboard Replacement: passo 6, imagem 2 %32
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: passo 7, imagem 1 %32 Dell Precision M6800 Keyboard Replacement: passo 7, imagem 2 %32
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
Conclusão
4 outras pessoas executaram este guia.
Szymon Milewski
Membro desde: 12/28/20
741 Reputação
Autoria de 3 guias
2 comentários
Great job, thank you
kali1902 - Responder
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 1,264
