Ir para o conteúdo principal
Dell Precision M6700 Hard Drive Replacement
O que você precisa
  1. Dell Precision M6700 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Dell Precision M6700 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M6700 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32 Dell Precision M6700 Hard Drive Replacement, Base Cover: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer
  3. Dell Precision M6700 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M6700 Hard Drive Replacement: passo 4, imagem 1 %32
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
  5. Dell Precision M6700 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the screw that secure that secondary hard drive in place.
    • Pull the tab upward and remove the secondary hard drive from the computer.
  6. Dell Precision M6700 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the screw that secure secondary hard drive to the bracket.
    • Remove the secondary hard drive from the bracket.
Conclusão
4 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.820 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 4,746
