Ir para o conteúdo principal
Dell Precision M6600 Hard Drive Replacement
O que você precisa
  1. Dell Precision M6600 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: passo 2, imagem 1 %32 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: passo 2, imagem 2 %32
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: passo 3, imagem 1 %32 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: passo 3, imagem 2 %32
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: passo 4, imagem 1 %32
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
Conclusão
4 outras pessoas executaram este guia.
Kaley lindsay
Membro desde: 03/23/18
582 Reputação
Autoria de 4 guias
Equipe
Um comentário
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 3,559
