Ir para o conteúdo principal
Dell Precision M6400 KeyBoard Replacement
O que você precisa
  1. Dell Precision M6400 KeyBoard Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 KeyBoard Replacement, Base Cover: passo 2, imagem 1 %32
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 KeyBoard Replacement, LED Cover: passo 3, imagem 1 %32
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 KeyBoard Replacement, KeyBoard: passo 4, imagem 1 %32
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 937
