Ir para o conteúdo principal
Dell Precision M6400 Hard Drive Replacement
O que você precisa
  1. Dell Precision M6400 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Hard Drive Replacement, Base Cover: passo 2, imagem 1 %32
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
    • Push in, then pull up on the safety loop to remove the cover.
    • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
  4. Dell Precision M6400 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
    • Set the pull tab aside to use with the replacement HDD1.
  5. Dell Precision M6400 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
    • Pull up on the pull tab to remove the carrier.
  6. Dell Precision M6400 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
    • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
    • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 40
Duração total: 4,106
