Ir para o conteúdo principal
Dell Precision M4800 Wi-Fi Card Replacement
O que você precisa
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 2 %32 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 3 %32
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
  2. Dell Precision M4800 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 2, imagem 2 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: passo 3, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 3, imagem 2 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 3, imagem 3 %32
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
  4. Dell Precision M4800 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: passo 5, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
  6. Dell Precision M4800 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 6, imagem 2 %32
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: passo 7, imagem 1 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 7, imagem 2 %32 Dell Precision M4800 Wi-Fi Card Replacement: passo 7, imagem 3 %32
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
Conclusão
Naveen
Membro desde: 09/19/23
195 Reputação
Autoria de 1 guia
Equipe
York University, Team B-19, Woodhouse Fall 2023 Membro de York University, Team B-19, Woodhouse Fall 2023
YORK-WOODHOUSE-F23SBG19
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 21
Últimos 30 dias: 59
Duração total: 313
