Ir para o conteúdo principal
Dell Precision M4600 KeyBoard Replacement
O que você precisa
  1. Dell Precision M4600 KeyBoard Replacement, Battery: passo 1, imagem 1 %32 Dell Precision M4600 KeyBoard Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
  2. Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: passo 2, imagem 1 %32 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: passo 2, imagem 2 %32 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: passo 2, imagem 3 %32
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
  3. Dell Precision M4600 KeyBoard Replacement, KeyBoard: passo 3, imagem 1 %32 Dell Precision M4600 KeyBoard Replacement, KeyBoard: passo 3, imagem 2 %32 Dell Precision M4600 KeyBoard Replacement, KeyBoard: passo 3, imagem 3 %32
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
  4. Dell Precision M4600 KeyBoard Replacement: passo 4, imagem 1 %32 Dell Precision M4600 KeyBoard Replacement: passo 4, imagem 2 %32 Dell Precision M4600 KeyBoard Replacement: passo 4, imagem 3 %32
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
  5. Dell Precision M4600 KeyBoard Replacement: passo 5, imagem 1 %32
    • Peel the keyboard data cable away from the keyboard and remove.
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,305
