O que você precisa
Turn the system badge fap over and place it on the base cover.
Remove the screws that secure the base cover to the computer. Release and remove the base cover from the computer.
Lift up and remove the base cover from the computer.
Disconnect the battery cable from the system board [1].
Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
Lift the battery off the computer [2].
Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
