Ir para o conteúdo principal
Dell Precision M3800 Hard Drive Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell Precision M3800 Hard Drive Replacement, Base Cover: passo 1, imagem 1 %32 Dell Precision M3800 Hard Drive Replacement, Base Cover: passo 1, imagem 2 %32
    • Turn the system badge fap over and place it on the base cover.
    • Remove the screws that secure the base cover to the computer. Release and remove the base cover from the computer.
    • NOTE: To remove the screws from the base cover, use a T5 Torx screwdriver.
    • Lift up and remove the base cover from the computer.
  2. Dell Precision M3800 Hard Drive Replacement, Battery: passo 2, imagem 1 %32
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  3. Dell Precision M3800 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Disconnect the hard-drive cable from the system board [1].
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard drive off the computer [2].
  4. Dell Precision M3800 Hard Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the hard-drive cable from the hard drive [1].
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket [2].
Conclusão
3 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.237 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
Um comentário
Very helpful guide! Easy to follow and helped me complete this task with ease
Chris Stockton - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 2,708
