Ir para o conteúdo principal
Dell Precision 7710 Memory Module Replacement
O que você precisa
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: passo 1, imagem 1 %32
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
  2. Dell Precision 7710 Memory Module Replacement, Battery: passo 2, imagem 1 %32
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: passo 3, imagem 1 %32
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: passo 4, imagem 1 %32 Dell Precision 7710 Memory Module Replacement, KeyBoard: passo 4, imagem 2 %32
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
  5. Dell Precision 7710 Memory Module Replacement: passo 5, imagem 1 %32
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: passo 6, imagem 1 %32
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
  7. Dell Precision 7710 Memory Module Replacement: passo 7, imagem 1 %32
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
Conclusão
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,678
