Ir para o conteúdo principal
Dell Precision 7560 Solid-State Drive (SSD) Replacement
O que você precisa
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: passo 1, imagem 1 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: passo 1, imagem 2 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: passo 1, imagem 3 %32
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 2, imagem 1 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 2, imagem 2 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 2, imagem 3 %32
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 3, imagem 1 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 3, imagem 2 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 3, imagem 3 %32
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): passo 4, imagem 1 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): passo 4, imagem 2 %32
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 5, imagem 1 %32 Dell Precision 7560 Solid-State Drive (SSD) Replacement: passo 5, imagem 2 %32
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
Conclusão
Hector
Membro desde: 02/14/23
261 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 46
Duração total: 804
