Ir para o conteúdo principal
Dell Precision 7560 Screen Replacement
O que você precisa
  1. Dell Precision 7560 Screen Replacement, Screen: passo 1, imagem 1 %32 Dell Precision 7560 Screen Replacement, Screen: passo 1, imagem 2 %32 Dell Precision 7560 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: passo 2, imagem 1 %32 Dell Precision 7560 Screen Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: passo 3, imagem 1 %32 Dell Precision 7560 Screen Replacement: passo 3, imagem 2 %32 Dell Precision 7560 Screen Replacement: passo 3, imagem 3 %32
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Conclusão
Laisha
Membro desde: 02/14/23
205 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 67
Ao todo: 1,067
