Ir para o conteúdo principal
Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
O que você precisa
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): passo 1, imagem 1 %32 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): passo 1, imagem 2 %32 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): passo 1, imagem 3 %32
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: passo 2, imagem 1 %32 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: passo 3, imagem 1 %32 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: passo 3, imagem 2 %32
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
Conclusão
Hector
Membro desde: 02/14/23
261 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
This is not for RAM this is for the SSD upgrades.
Kurtis - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 528
