Introdução
This guide covers how to replace the battery in a Dell Precison 7560. When replacing the battery, make sure to completely power off your device. Not doing so will cause a Fire Hazard. The battery is responsible for powering your device, so it is very hazardous.
O que você precisa
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Uma outra pessoa concluiu este guia.
