Ir para o conteúdo principal
Dell Precision 7510 KeyBoard Replacement
O que você precisa
  1. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: passo 1, imagem 1 %32
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: passo 2, imagem 1 %32
  3. Dell Precision 7510 KeyBoard Replacement, Removing the Hard Drive: passo 3, imagem 1 %32
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 KeyBoard Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
  5. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard Cables: passo 5, imagem 1 %32
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard: passo 6, imagem 1 %32
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
Linha de Chegada
4 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.034 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.987 guias
Um comentário
Einfach und verständlich geschrieben. Habs ohne Probleme geschafft :-)
Nur hab ich mich gefragt: Wozu Schritt 4?! Der ist zum Entfernen der Tastatur gar nicht nötig.
Wer also nur die Tastatur wechseln möchte, kann von 3 gleich zu 5 springen.
Danke für die Anleitung.
Hat mir sehr geholfen.
f_siman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 3,788
