Ir para o conteúdo principal
Dell Precision 5520 Hard Drive Replacement
O que você precisa
  1. Dell Precision 5520 Hard Drive Replacement, Base Cover: passo 1, imagem 1 %32 Dell Precision 5520 Hard Drive Replacement, Base Cover: passo 1, imagem 2 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Hard Drive Replacement, Battery: passo 2, imagem 1 %32
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the four M2x4 screws securing the hard-drive bracket to the computer [1].
    • Lift the hard-drive cage [2] off the hard drive assembly [3].
  4. Dell Precision 5520 Hard Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the hard-drive cable from the system board [1].
    • Lift the hard drive off the palm rest assembly [2].
  5. Dell Precision 5520 Hard Drive Replacement: passo 5, imagem 1 %32
    • Disconnect the hard drive interposer from the hard drive assembly and then remove the hard drive covers away from the hard drive.
Conclusão
4 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 68
Duração total: 7,291
