Ir para o conteúdo principal
Dell Precision 5510 RAM Replacement
O que você precisa
  1. Dell Precision 5510 RAM Replacement, Base Cover: passo 1, imagem 1 %32
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 RAM Replacement: passo 2, imagem 1 %32
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: passo 3, imagem 1 %32 Dell Precision 5510 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: passo 4, imagem 1 %32
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: passo 5, imagem 1 %32
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: passo 6, imagem 1 %32
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
Conclusão
Cooper Zuranski
Membro desde: 03/31/22
109 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Harley Spring 2022 Membro de IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Membros
Autoria de 4 guias
1Comentário do guia
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 713
