Ir para o conteúdo principal
Dell Precision 5510 Keyboard Replacement
O que você precisa
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: passo 1, imagem 1 %32
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: passo 2, imagem 1 %32
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: passo 3, imagem 1 %32 Dell Precision 5510 Keyboard Replacement, Fans: passo 3, imagem 2 %32
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: passo 4, imagem 1 %32 Dell Precision 5510 Keyboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: passo 5, imagem 1 %32 Dell Precision 5510 Keyboard Replacement: passo 5, imagem 2 %32
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: passo 6, imagem 1 %32 Dell Precision 5510 Keyboard Replacement, Battery: passo 6, imagem 2 %32
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: passo 7, imagem 1 %32 Dell Precision 5510 Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: passo 8, imagem 1 %32 Dell Precision 5510 Keyboard Replacement: passo 8, imagem 2 %32
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: passo 9, imagem 1 %32
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: passo 10, imagem 1 %32
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: passo 11, imagem 1 %32
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: passo 12, imagem 1 %32
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: passo 13, imagem 1 %32
    • Pull keyboard out and replace.
Conclusão
Colin Hunter
Membro desde: 03/31/22
121 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Harley Spring 2022 Membro de IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Membros
Autoria de 4 guias
1Comentário do guia
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 2,753
