Ir para o conteúdo principal
Dell Photo Printer 720 Encoder Strip Replacement
O que você precisa
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: passo 1, imagem 3 %32
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 2, imagem 3 %32
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: passo 3, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 3, imagem 2 %32
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 1 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 2 %32 Dell Photo Printer 720 Encoder Strip Replacement: passo 4, imagem 3 %32
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
Conclusão
Uma outra pessoa concluiu este guia.
Megan Lawrence
Membro desde: 01/14/15
534 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 487
