Ir para o conteúdo principal
Dell Optiplex SX280 Upper Fan Replacement
O que você precisa
  1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Upper Fan Replacement: passo 2, imagem 1 %32 Dell Optiplex SX280 Upper Fan Replacement: passo 2, imagem 2 %32
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Upper Fan Replacement: passo 3, imagem 1 %32 Dell Optiplex SX280 Upper Fan Replacement: passo 3, imagem 2 %32
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: passo 4, imagem 1 %32 Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: passo 4, imagem 2 %32
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Upper Fan Replacement: passo 5, imagem 1 %32 Dell Optiplex SX280 Upper Fan Replacement: passo 5, imagem 2 %32
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Dell Optiplex SX280 Upper Fan Replacement: passo 6, imagem 1 %32 Dell Optiplex SX280 Upper Fan Replacement: passo 6, imagem 2 %32
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
  7. Dell Optiplex SX280 Upper Fan Replacement: passo 7, imagem 1 %32
    • Pull the upper fan out of the computer.
Conclusão
7 outras pessoas executaram este guia.
Tom
Membro desde: 10/04/10
841 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 22-4, Maness Fall 2010 Membro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
Membros da 4
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 5,274
