Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
Pull the heat sink out of the computer while pressing on the release tab.
Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
Remove the rubber grommets from the base of the fan. A spudger may be useful.
Press on the blue release tab and pull the upper fan out of the computer.
Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
The RAM are the two green cards in the corner of the computer.
At each end of the card, there are two white clips securing the RAM to the Motherboard.
Push down both white clips with your thumbs until you hear a click.
The RAM cards can now be removed.
Unplug the blue cable that connects the hard drive to the motherboard.
Unplug the power supply, distinguished by its red and yellow wires.
Squeeze the release tabs on either side of the hard drive.
Then slide the hard drive out of the computer while squeezing the tabs.
Unplug the cable that connects the hard drive to the Motherboard.
Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
Unplug the power cable attached to the motherboard speaker.
Remove four screws located at the back of the computer tower.
Carefully detach the motherboard from the computer case.
Lift the motherboard from the rest of the computer case.
Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
Unplug the cable that powers the emergency shut off, distinguished by its red wires.
Slide the Hard Drive Stand to left side.
Remove the stand from the rest of the rear panel.
Remove the studs that support the Hard Drive Stand from the motherboard.
Remove the four screws located on heat sink stand.
The heat sink stand can now be lifted from the motherboard.
Remove the four screws holding the motherboard to the rear computer panel.
The motherboard can now be removed from the remaining panel.
11 outras pessoas executaram este guia.
2 comentários
Good job. Thanks for sharing, friend.
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
