Ir para o conteúdo principal
Dell Optiplex SX280 Lower Fan Replacement
O que você precisa
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: passo 2, imagem 1 %32 Dell Optiplex SX280 Lower Fan Replacement: passo 2, imagem 2 %32
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: passo 3, imagem 1 %32 Dell Optiplex SX280 Lower Fan Replacement: passo 3, imagem 2 %32
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: passo 4, imagem 1 %32 Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: passo 4, imagem 2 %32
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: passo 5, imagem 1 %32
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: passo 6, imagem 1 %32 Dell Optiplex SX280 Lower Fan Replacement: passo 6, imagem 2 %32
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: passo 7, imagem 1 %32 Dell Optiplex SX280 Lower Fan Replacement: passo 7, imagem 2 %32
    • Press on the blue release tab and remove the fan.
Conclusão
3 outras pessoas executaram este guia.
Tom
Membro desde: 10/04/10
841 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 22-4, Maness Fall 2010 Membro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
Membros da 4
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 4,212
