Ir para o conteúdo principal
Dell Optiplex SX280 Heat Sink Replacement
  1. Dell Optiplex SX280 Heat Sink Replacement, Panel Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Heat Sink Replacement: passo 2, imagem 1 %32 Dell Optiplex SX280 Heat Sink Replacement: passo 2, imagem 2 %32
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Heat Sink Replacement: passo 3, imagem 1 %32 Dell Optiplex SX280 Heat Sink Replacement: passo 3, imagem 2 %32
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: passo 4, imagem 1 %32 Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: passo 4, imagem 2 %32
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Dell Optiplex SX280 Heat Sink Replacement: passo 5, imagem 1 %32 Dell Optiplex SX280 Heat Sink Replacement: passo 5, imagem 2 %32
    • Press down on the release tab above the heat sink.
  6. Dell Optiplex SX280 Heat Sink Replacement: passo 6, imagem 1 %32 Dell Optiplex SX280 Heat Sink Replacement: passo 6, imagem 2 %32
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
Conclusão
4 outras pessoas executaram este guia.
Tom
Membro desde: 10/04/10
841 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 22-4, Maness Fall 2010 Membro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
Membros da 4
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 6,226
