Ir para o conteúdo principal
Dell Optiplex SX280 Hard Drive Replacement
  1. Dell Optiplex SX280 Hard Drive Replacement, Panel Cover: passo 1, imagem 1 %32
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Hard Drive Replacement: passo 2, imagem 1 %32 Dell Optiplex SX280 Hard Drive Replacement: passo 2, imagem 2 %32
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Hard Drive Replacement: passo 3, imagem 1 %32 Dell Optiplex SX280 Hard Drive Replacement: passo 3, imagem 2 %32
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Dell Optiplex SX280 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Hard Drive Replacement: passo 5, imagem 1 %32 Dell Optiplex SX280 Hard Drive Replacement: passo 5, imagem 2 %32
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Hard Drive Replacement: passo 6, imagem 1 %32
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Hard Drive Replacement: passo 7, imagem 1 %32 Dell Optiplex SX280 Hard Drive Replacement: passo 7, imagem 2 %32
    • Slide the Hard Drive out while squeezing the tabs.
Conclusão
6 outras pessoas executaram este guia.
Wyatt
Membro desde: 10/06/10
775 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 22-4, Maness Fall 2010 Membro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
Membros da 4
Autoria de 26 guias
2 comentários
Thanks for great tutorial.
Politers - Responder
Yeah great tutorial!
Rebinas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 5,865
