Ir para o conteúdo principal
Dell Optiplex GX620 Side Panel Disassembly
  1. Dell Optiplex GX620 Side Panel Disassembly, How to unplug and discharge before repair: passo 1, imagem 1 %32 Dell Optiplex GX620 Side Panel Disassembly, How to unplug and discharge before repair: passo 1, imagem 2 %32
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Side Panel Disassembly: passo 2, imagem 1 %32 Dell Optiplex GX620 Side Panel Disassembly: passo 2, imagem 2 %32
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Side Panel Disassembly, Dell Optiplex GX620 Side Panel Disassembly: passo 3, imagem 1 %32
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
Conclusão
9 outras pessoas executaram este guia.
Kristina
Membro desde: 09/03/14
210 Reputação
Autoria de 7 guias
Equipe
Pasco Hernando, Team 5-1, Prince Fall 2014 Membro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
Membros da 10
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 8,878
