Introdução
The GX620 has a 3.5 inch floppy disk drive. The back end of the traditional floppy drive contains a port for a standard cable that connects to the motherboard. Also here is a connection for power from the power supply.
O que você precisa
Power down your PC and remove the power cord from the back.
With the computer standing upright, firmly pull on the tab at the back of the computer.
When the side panel pops free, gently pull the panel away from the computer.
Slide the blue latch downward until the panel can be removed from it's hinges.
Gently remove the floppy-drive and power cables from the back of the floppy drive.
With a Phillips #1 screwdriver, remove the screws connecting the floppy drive to the drive bay. Set the screws aside in a location where you may use them at a later time.
To remove the unconnected floppy drive from the drive bay, slide the drive towards the front of the computer.
Uma outra pessoa concluiu este guia.
