Ir para o conteúdo principal
Dell Optiplex GX620 CMOS Battery Replacement
O que você precisa
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: passo 1, imagem 1 %32 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: passo 1, imagem 2 %32
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: passo 2, imagem 1 %32 Dell Optiplex GX620 CMOS Battery Replacement: passo 2, imagem 2 %32
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: passo 3, imagem 1 %32
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: passo 4, imagem 1 %32
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
7 outras pessoas executaram este guia.
Kristina
Membro desde: 09/03/14
198 Reputação
Autoria de 7 guias
Equipe
Pasco Hernando, Team 5-1, Prince Fall 2014 Membro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
Membros da 10
Autoria de 15 guias
2 comentários
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - Responder
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 50
Duração total: 15,452
