Ir para o conteúdo principal
Dell Optiplex 745 Small Form Factor Processor Replacement
O que você precisa
  1. Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: passo 1, imagem 1 %32 Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: passo 1, imagem 2 %32
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Processor Replacement: passo 2, imagem 1 %32 Dell Optiplex 745 Small Form Factor Processor Replacement: passo 2, imagem 2 %32
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Processor Replacement, Processor: passo 3, imagem 1 %32
    • The processor is located inside the heat sink (indicated by the marker).
  4. Dell Optiplex 745 Small Form Factor Processor Replacement: passo 4, imagem 1 %32 Dell Optiplex 745 Small Form Factor Processor Replacement: passo 4, imagem 2 %32 Dell Optiplex 745 Small Form Factor Processor Replacement: passo 4, imagem 3 %32
    • Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
    • If the processor is glued on to the heat sink, gently scrape off the glue and detach it from the device.
  5. Dell Optiplex 745 Small Form Factor Processor Replacement: passo 5, imagem 1 %32 Dell Optiplex 745 Small Form Factor Processor Replacement: passo 5, imagem 2 %32 Dell Optiplex 745 Small Form Factor Processor Replacement: passo 5, imagem 3 %32
    • Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
    • Remove the processor from its casing.
Conclusão
3 outras pessoas executaram este guia.
Abdullah Khan
Membro desde: 10/03/17
181 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 1,245
