Ir para o conteúdo principal
Dell Optiplex 745 Small Form Factor Optical Drive Replacement
  1. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: passo 1, imagem 1 %32 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Opening the case: passo 1, imagem 2 %32
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Optical Drive Replacement: passo 2, imagem 1 %32 Dell Optiplex 745 Small Form Factor Optical Drive Replacement: passo 2, imagem 2 %32
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: passo 3, imagem 1 %32 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Disconnecting the cables: passo 3, imagem 2 %32
    • Pull out both sets of cables from the side of the optical drive.
    • Both cables are plugged into the drive right next to each other.
  4. Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: passo 4, imagem 1 %32 Dell Optiplex 745 Small Form Factor Optical Drive Replacement, Removing the optical drive: passo 4, imagem 2 %32
    • Pull the tab up holding the optical drive in place.
    • Slide the optical drive out.
Conclusão
9 outras pessoas executaram este guia.
Tyler Whalen
Membro desde: 09/29/14
835 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 13-10, Forte Fall 2014 Membro de Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
Membros da 6
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 1,977
