Ir para o conteúdo principal
Dell Optiplex 745 Small Form Factor Motherboard Replacement
O que você precisa
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: passo 1, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: passo 1, imagem 2 %32
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 2, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 2, imagem 2 %32
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, imagem 2 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, imagem 2 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, imagem 2 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, imagem 1 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, imagem 2 %32 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, imagem 3 %32
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
Conclusão
7 outras pessoas executaram este guia.
Alexander Rosner
Membro desde: 10/03/17
291 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 1,806
