Ir para o conteúdo principal
Dell Optiplex 745 Small Form Factor Graphics Card Replacement
  1. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, imagem 1 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, imagem 2 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, imagem 3 %32
    • Pull the tab on the cover to release the lid.
    • Remove the cover to expose the computer.
  2. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, imagem 1 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, imagem 2 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, imagem 3 %32
    • The graphics card has a fan built into it and is fasten by two blue clips.
    • Pull up the top blue clip that is above the graphics card while holding the graphics card in place.
  3. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, imagem 1 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, imagem 2 %32 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, imagem 3 %32
    • Below the graphics card, there is a second clip that holds the card in place.
    • With one hand, pull back the clip while lifting the graphics card with the other.
  4. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 4, imagem 1 %32
    • Remove the graphics card.
Conclusão
Daviel Almonte
Membro desde: 10/03/17
155 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Membros da 4
Autoria de 9 guias
Um comentário
Graphic card modal no please
Mans Manshion - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 2,466
