Ir para o conteúdo principal
Dell Optiplex 745 Small Form Factor Audio Components Replacement
O que você precisa
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: passo 1, imagem 1 %32 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: passo 1, imagem 2 %32
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 2, imagem 1 %32 Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 2, imagem 2 %32
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: passo 3, imagem 1 %32
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 4, imagem 1 %32
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 5, imagem 1 %32 Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 5, imagem 2 %32
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy Nicholas
Membro desde: 10/09/17
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro de USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Duração total: 1,147
