Introdução
This guide will walk you through step by step how to replace the Motherboard of a Dell Optiplex 745 Desktop. In order to do so, we will have to remove the casing as well as all the core components of the computer to access the Motherboard.
The Motherboard of a computer is the most vital part of the computer. It's essentially the "brain" of the computer. It tells all the components what to do and when to do it to ensure everything operates together efficiently.
O que você precisa
Orientate the computer so the case lock is on the left corner, like so.
Pull the tab that locks the casing in place.
While the tab is pulled, lift the casing off the computer.
4 outras pessoas executaram este guia.
1Comentário do guia
Thank you and your contributors for providing this guide. I did not replace motherboard but three 2200 u capacitors on it. The thing works again!
