O que você precisa
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Locate the power supply in the case.
Disconnect the AXT power cable to the motherboard.
Disconnect the P4 12 volt power cable from the motherboard.
Disconnect the power cable from the optical drive.
Disconnect the floppy drive power cable.
Disconnect the hard drive power cable.
6 outras pessoas executaram este guia.
1Comentário do guia
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
