Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you. Push the  oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Locate the power supply in the case.
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  5. Push down on the green tab with one hand.
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
Conclusão
3 outras pessoas concluíram este guia.
Kevin Schapansky
Membro desde: 05-10-2010
1.199 reputação
9 Guias de autoria
Equipe
Cal Poly, Team 4-48, Amido Fall 2010 Membro de Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membros
18 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 36
Todo: 11,175
